calculating phase difference of two signal from signal generator
I used two sinusoidal signals from signal generator. I want to calculate the phase difference between them. I apply the "fft" and the "complex to Arg" block in GNURadio.  the center frequency is 600 MHz and the sample rate is 8MHz.
but when I run the flowgraph a window is opened for just 1sec and then it is closed and nothing else happens! I would be thankful if you tell me if there is somthing wrong.
Thank you
(3,658 Views)
If the signals that you are wanting to know the phase difference between are sinewaves, it would seem to me that the phase difference is simply the delay between zero-crossing points or some other reference point.
Next, you are mention a flowgraph. Do you mean your program? What window is opened, and what does it say?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,642 Views)
I fixed that problem Mike.
Thank you
the problem was that I had put 2 uhd sources block in my program instead of one source and two channels. 🙂 and also my signals are sinusoid.
but now another problem is that the phase difference that is calculated is changing. I mean once it says 2.2 radian (which is correct since my inputs have 180 degree phase difference) and a few seconds later it changed to another number like 0.3 !!! and other numbers.
Thank you again for your help
(3,637 Views)
Please post your VI with some typical data saved as default (we do not have your hardware). It is very difficult to debug a paragraph.
Lynn
(3,634 Views)
If you plot the two waveforms as they are acquired, are they indeed 180 degrees apart? and not changing?
Mike...
LabVIEW Champion
(3,630 Views)
