Wifi with raspberry Pi 4
How much of a vacuum are you going to try to pull?  When you get down really close to total vacuum, things like tape adhesive or some board coatings will want to outgas, and you'll have a really hard time getting there.  Even fingerprints will want to outgas at this point!
Bill
CLD
(Mid-Level minion.)
Message 11 of 52
(2,063 Views)
Deep Vacuum without a fully operational high class clean room environment is not really practical. That includes of course use of protective clothing and gloves when handling anything that goes into the vacuum chamber. And yes selection of things like insulation, adhesive tape and even cabling has to be done very carefully.
I assume one of the two available bulkheads does provide power. I can't even start to imagine the trouble to select a battery that will not cause problems in vacuum.
Rolf Kalbermatter  My Blog
Message 12 of 52
(2,037 Views)
@taestygecko wrote:
Yes this is something I have told researchers yet they insist of trying it out anyway
Is there budget for quantum entanglement?
Getting it small enough (esp. without tape) might be tricky. But "try it out anyway" seems like a card blanche to me. And they are researchers 🤣.
Message 13 of 52
(2,027 Views)
At the moment it wont be extra low pressure just yet so outgassing is not too big of an issue but It will be converted and when that happens I will be investigating this more, we have already decided on using kapton wire and tape for the parts we need to replace
Message 14 of 52
(1,980 Views)
These guys do have a pretty big budget, so I have come up with a few solutions in case anything goes wrong but we are also researching how this device will work inside a ultra low pressure
Message 15 of 52
(1,977 Views)
So I suppose with the glass window there was enough to get WIFI to work through the glass which is amazing
Message 16 of 52
(1,976 Views)
You were able to get it to work?  NICE.  Don't forget to mark your post where as the solution.  🙂
Bill
CLD
(Mid-Level minion.)
Message 17 of 52
(1,952 Views)
Well there is no solution to this yet as I still don't know how to get LABview to control my PWM on my Raspberry Pi via WIFI.
Message 18 of 52
(1,924 Views)
According to your first post and the subject of this topic, your question about wifi has been answered.  It is appropriate to mark this topic as "solved", and if you have a different question, create a new topic.
Bill
CLD
(Mid-Level minion.)
Message 19 of 52
(1,909 Views)
My original topic is about getting LABview to connect to my Raspberry Pi via WIFI this has not been solved, all we have clarified is that the wifi signal can generate through a vacuum chamber.
Message 20 of 52
(1,889 Views)
