Wiimote VIs in cRio?
I've downloaded the wiimote Vis from this thread http://forums.ni.com/ni/board/message?board.id=170&thread.id=249428&view=by_date_ascending&page=1 but wasnt sure if they would work if i loaded them in a CRio or a similar controller.
(2,408 Views)
It should work on a 9002 or 9004 cRio (the .dll file used means it shouldn't run on other versions) although I haven't tested it myself.  If you have the hardwear then the best thing to do is have a go!
It would be great if you could let me know how you get on,
Tom Clark
Applications Engineer
National Instruments UK & Ireland
(2,378 Views)
