Windows 10 and EtherCAT
Has anyone found a workaround to the problem of Windows 10 not supporting EtherCAT?
I'm trying to update a system with a cRIO that uses an NI-9144 chassis.
See the Hardware Driver section of the following:
National Instruments Product Compatibility for Microsoft Windows 10
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,883 Views)
Accepted by stevem181
Can you attach the MAX report here? Have you tried the EtherCAT 17.6?
(4,866 Views)
I'm no expert, but looked at this a few times before.
As far as I understand, EtherCAT needs an EtherCAT device to enable deterministic EtherCAT. Ethernet (e.g. any network card) can communicate nondeterministic EtherCAT, but most drivers will refuse or disallow it.
I could be wrong a bit or completelly...
(4,820 Views)
Thanks Yin_W! You pointed me in the right direction.
I'm using LabVIEW 2015 sp1 so I installed version 16 CompactRIO drivers and EtherCat 16.1 and it worked.
The Windows 10 compatibility page is wrong (didn't see a way to report it).
steve
(4,814 Views)
Thank you for the feedback. After checking, NI has already been aware of this issue. The Windows 10 compatibility page is under reviewing now.
(4,766 Views)
