05-07-2018
05:52 PM
- last edited on
11-04-2025
12:45 PM
by
Content Cleaner
Has anyone found a workaround to the problem of Windows 10 not supporting EtherCAT?
I'm trying to update a system with a cRIO that uses an NI-9144 chassis.
See the Hardware Driver section of the following:
National Instruments Product Compatibility for Microsoft Windows 10
steve
Solved! Go to Solution.
05-07-2018 07:05 PM
Can you attach the MAX report here? Have you tried the EtherCAT 17.6?
05-08-2018 05:56 AM
I'm no expert, but looked at this a few times before.
As far as I understand, EtherCAT needs an EtherCAT device to enable deterministic EtherCAT. Ethernet (e.g. any network card) can communicate nondeterministic EtherCAT, but most drivers will refuse or disallow it.
I could be wrong a bit or completelly...
05-08-2018 07:07 AM
Thanks Yin_W! You pointed me in the right direction.
I'm using LabVIEW 2015 sp1 so I installed version 16 CompactRIO drivers and EtherCat 16.1 and it worked.
The Windows 10 compatibility page is wrong (didn't see a way to report it).
steve
05-11-2018 03:46 AM
Thank you for the feedback. After checking, NI has already been aware of this issue. The Windows 10 compatibility page is under reviewing now.
