Windows 7 compatibility
Hello
I use labview 8.2.1 and NI Vision . Is it possible to achieve the same efficiency if I use the LabVIEW 8.2.1 exe at windows 7(32/64 bit) machine with compatible run time engine ?
If I want to develop LabVIEW application in windows 7 , I will have to purchase/upgrade LabVIEW 2009 or above . Am I correct ? In  that case NI Vision module also have to be upgraded to 2009 or above ?
Thanks and Regards
Anoop
(2,628 Views)
Did you try a search? This question has been asked dozens of times and there are lots of articles in the NI KnowledgeBase which would have been found from a simple search. But let me do that for you...
Windows Version Compatibility with LabVIEW
LabVIEW Module and Toolkit Compatibility Information [broken link removed]
National Instruments Minimum Version Requirements for Microsoft Windows 7
(2,622 Views)
