charecter to hex
Hi
i want to conver string to hex
what i mean i want to convert "wisam" it string that i want to cover it to hex
how can i do that in labview
thanks
(3,092 Views)
Hi
check the  attached file
(3,087 Views)
(3,086 Views)
Hi
can you save the file so i can open it with labview v2009
thanks
(3,076 Views)
(3,072 Views)
If you want the Hex values, you can use the first portion of the code from Zekasa and set the display to Hexadecimal.
That way, it is still a numeric but you see it as Hexadecimal.
In other words, all you need is the "String to Byte Array" function.
(3,044 Views)
