Windows CE-base device testing and debugging
I have a Windows CE-based device, a GPS device, to test and debug. The device already has its own application SW, a non-NI application SW, loaded.
Is there a LabVIEW toolkit I can used to communicate and test this kind of device?
If you can also point me to some tutorial materials, I would appreciate that.
Thanks in advance!
(2,792 Views)
Simply typing GPS into the search window at the very top of the page would have given you this as the first result.
(2,787 Views)
