Windows Locale_Info Constants
Anyone got a (name<=>number) translation table for Locale Info type identifier constants (e.g. LOCALE_ITIME) associated with Windows API GetLocaleInfo.dll?  I can't seem to find it on the Microsift site.
Thanks!
(3,540 Views)
(3,535 Views)
Thanks.  Know what?  I tried not to ask the original question with a story, but the story is that I went in circles starting exactly where you suggested.  I learned about everythiing but the numeric values--not to suggest I'm incapable of overlooking things that are under my nose of course.  Well, finally I got the answer via Google, no thanks to msdn in this case.
Here is where I found it...
http://www.freevbcode.com/ShowCode.asp?ID=116&NoBox=True
(3,520 Views)
You usually will have to find a source outside of MS.  Since all these names are included in header files, C and VB programmers use the names and the proper include.  They don't need to know the actual values like us poor LV programmers.  I often am searching for header files online.
(3,516 Views)
