Windows notifications
Hi!! I'm new to the forums.
I would like to know if a message can be generated in Windows notifications from LabVIEW, very similar to email notifications.
For example, when a Boolean changes, the notification information would be received as the attached image.
If this is possible, what topics do I need to know or in what blocks should I look?
Thank you
(5,843 Views)
I don't think you can do this directly.
You will probably have to use some sort of ActiveX property node or something like that to get to the Windows API calls for Notification Class
=== Engineer Ambiguously ===
(5,826 Views)
I'll try it, thanks!
(5,821 Views)
Accepted by Dcampu90
Actually you can do this in a LabVIEW pre-built package.
  1. Go to VIPM and download the Averna Notify Icon Package.
  2. Check out this link
Both use the Windows API mentioned, but are already built.
mcduff
(5,785 Views)
I just recently added some bells and whistles a program with this exact package.
Make sure you read all the comments as there are a lot of good tips in there.
Former Certified LabVIEW Developer (CLD)
(5,777 Views)
