Windows size change
I may need to change the windows size of the vi as the screenshot.
When click on the black arrow pointing right, the whole window size will increase, ie. the right edge will move to make window bigger, another chart will appear.
When click on the black arrow pointing left, the whole window size will decrease, ie. the right edge will move to make window smaller, another chart will disappear.
Any suggestion, thanks.
(3,601 Views)
Hi alex.,
you can use property nodes to change the window size and to show/hide the second chart.
Mike
(3,597 Views)
Thanks, may I know how to use property node to change it.
Also, can it be changed slowly like an animation.
(3,594 Views)
Hi alex.,
see the attached example.
Mike
(3,584 Views)
Accepted by topic author alex.
Here an example
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
(3,571 Views)
