sinewaveform Generation
Dear All,
Iam new to labVIEW. Iam using labview version 7.1. In that i need to generate sinewave form by using Frequency 4hz , linear amplitude 10mm and  angular amplitude 5Deg. Can any one help this to generate sinewaveform by using above parameters.
Thanks in advance,
Vijay
(2,837 Views)
how about using "Basic function generator.vi"
You will find it by right click on the block diagram and going to the following pallette
Programming->Waveform->Analog Waveform->Waveform Generation->Basic function generator.vi
Craig
LabVIEW 2012
(2,818 Views)
Hi
Go help in the toolbar. Then select Find examples, and search for function. That should help you out. Also while you are in help be sure to enable Show context Help.
Good luck and have fun
Message Edited by Coq Rouge on 02-19-2010 10:10 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,816 Views)
