Wire labels moving out of position
Hello all,
I'm having a very frustrating issue with my wire labels. For some reason, all my wire labels seem to get moved up and I have to go back and reposition them. It seems to happen each time I open labview. Here's a screenshot of what I'm talking about. The ones that are in the correct position I already fixed. The "Index for Inc. Px" should be on the blue wire, the "Serial #" on the blue wire and the "Sealed/ATM Conversion" on the orange wire.
Anyone else have this problem?
Message 1 of 12
(3,729 Views)
What version of LV are you using?
Are those free labels hovering above/at wires or are they "wire labels"?
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(3,726 Views)
LV 2011. They are wire labels, not free labels.
Message 3 of 12
(3,723 Views)
The VI was developed in LV 2011? Was it developed on the same machine?
If not, what are the differences?
Norbert
Norbert
Expert: Geometry
Message 4 of 12
(3,706 Views)
The VI was developed in LV 2011 and was developed on the same machine.
Message 5 of 12
(3,703 Views)
Hm...
how big is the block diagram?
Background: The block diagram has a limited size (just as the front panel) where it works correctly. So maybe you left the valid bounds.....
Norbert
Norbert
Expert: Geometry
Message 6 of 12
(3,701 Views)
It's pretty large. My resolution is 1920x1080 and I have to scroll vertically.
Message 7 of 12
(3,698 Views)
Then i suggest you to shrink the BD to about 1200x1024. You can use subVIs (hopefully) to make algorithms "to appear smaller" in your main VI.
I am not sure, if this solves your issue, but i know that leaving the bounds of the BD has some weird issues in its backpack.
Norbert
Norbert
Expert: Geometry
Message 8 of 12
(3,691 Views)
I'll try that. Thanks for the suggestion Norbert. I didn't realize there are block diagram boundaries and they would cause this issue.
Take care
Message 9 of 12
(3,687 Views)
As i said, i cannot garantuee that this changes the issue. But i have never seen this behavior on any other machine.
And i have seen weird (different) things with BD growing too large so i just want to give that a shot.
thanks,
Norbert
Norbert
Expert: Geometry
Message 10 of 12
(3,685 Views)
