Wireless Detect
Good afternoon,
my pc is connected to a wireless network, how do I do in labview to know the status of that connection?
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
(3,929 Views)
If you just want to know if the network is up, try the IsNetworkAlive WinAPI Funtion.  I have attached a VI which calls it.
(3,915 Views)
Hi, you can send me, to previous versions?
Hugo Santos
(3,888 Views)
What version do you need it in?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,883 Views)
Accepted by hugosantos
Here it is saved to 8.2.  It is the earliest I can save back without the stupid error cluster wire breaking.  If you need an earlier version, you'll probably need to go to the version converison board, as I can't easily get back further without installed an older version of LV.
(3,875 Views)
Thanks a lot, this is I wanted.
With best regards
Hugo Santos
(3,864 Views)
