I can get the x values of each function to display on the front panel with no problems, but I have not been able to acquire this information from the front panel.
You use a property node to programtically retrieve the cursor values. For each cursor, first use the property Active Cursor to select (0 for the first and 1 for the second) and then the property Cursor Position:Cursor X. See the attachment.
