Working with ActiveX object that is not creatable in Labview
OnSetUserDefinedCommand, OnStateChanged, and OnUserDefinedCommandSelected shows up as events
That's the problem here. The ICaymanMachineInfo interface is an event interface. You're not supposed to create objects of it. The ActiveX-Server you're communicating with creates the appropriate objects
on client request. You have to use the Register Event Callback primitive to register for events defined by this interface. In order to do that you have to create an ICaymanMachine object.
Message 11 of 12
(1,028 Views)
Accepted by MTHPCB
Message 12 of 12
(1,024 Views)
