Working with shift registers for finding index of threshold point.
In your FALSE case, you wired up the input tunnel.  It should be the one coming from the shift register.
Message 11 of 17
(1,712 Views)
Wired the ouput shift register with the input shift register for the false statement
Result:
The previous and the new values are the same. The subtraction shows 0 result.
heartbeat = infinty.
Message 12 of 17
(1,710 Views)
Accepted by anupam2016
I think what is happening is your value is staying above the threshold for more than 1 sample, and therefore you are getting indexes that are right next to each other.  Since we only care about the rising edge for the sake of our calculations here, use a Boolean Crossing PtByPt to only perform the calculation when the threshold detector result goes from FALSE to TRUE.
Message 13 of 17
(1,698 Views)
I tried implementing the Boolean crossing ptbypt VI. I wired the output of the threshold pt by pt into the input of booleancrossing ptbypt. I set the direction to false from true. The results were similar to previous tries. Both the shift registers gave same values, making heartbeat = infinite.
I also tried making the direction to true to false , but it gave no results. i.e: The shiftregisters seemed to not get updated.
Can you suggest me something else which I can try?
P.S:I am uploading my modified VI.
Message 14 of 17
(1,687 Views)
  • Do you have a stretch of typical voltage data that we can use to play back and test? We don't have your instrument.
  • Why the boolean crossing? Why don't you just check if the index has changed instead, that would ensure that the value differ and you don't get a division by zero.
  • Your diagram comment is differs 180 degrees from the actual setting you use (true-false vs. false-true).
  • How noisy is the data? Wouldn't it make more sense to analyze the threshold of the filtered data?
  • Is this the established way to analyze that kind of data or did you come up with that?
Message 15 of 17
(1,681 Views)
Will a TDMS file work. I am attaching it.
I was told to use boolean crossing, after number of tries.
The comment in the diagram is a mistake.
Noisy is present, but is negligible in contrast to the signal.
Similar logic is used in few videos where implementation is in MATLAB.
Message 16 of 17
(1,679 Views)
Seems to work just fine. Did you set the threshold correctly?
Message 17 of 17
(1,675 Views)
