Working with spectrometer, how to make compatible with LabVIEW and SpectraSuite at same time?
Hi all,
I've been browsing the forums for a while looking at how people have interfaced with ocean optics spectrometers, but I haven't seen a reference to my problem. I have the HR4000 from ocean optics, and have been able to successfully use NI's drivers for it by installing it as an NI-VISA device over USB. Unfortunately, when I have it installed with the NI-VISA driver, I cannot use it with SpectraSuite (ocean optics' software). When I click "update driver" and it installs it as a regular USB device (as opposed to NI-VISA) it works with SpectraSuite, but of course not with my LabVIEW program. If anyone has a work around for this, please lend me any insight you can!
gregoryj
(4,467 Views)
gregoryj,
In order for your device to work with LabVIEW it will need to use the NI-VISA driver.  Likewise the device manufacturer’s software will also need its own driver installed to communicate with the HR4000.  Unfortunately you cannot have multiple drivers installed for a single device.  As you mentioned manually replacing the driver is the only way to switch between control programs.
Sam K
(4,418 Views)
Hi, in my case, I have 4 USB outputs on my laptop, where one of them is used for Spectrasuite and other 3 are for LV.
So you don't have to reinstall drivers for the spectrometer, just switch between USB ports
(4,135 Views)
