Wrap text in tables?
Is there any way to wrap the text in a table?
Specifically the column headers.
If I have a header like Input Voltage I would like it to wrap like in Excel
Input
Voltage
So the column width does not need to be set wire just to read the headers
=== Engineer Ambiguously ===
(3,819 Views)
Accepted by RTSLVU
Use a property node to set up your column headers and include a new line between Input and Voltage. When the data going to the property node is viewed as code display you will see 'Input\nLevel'.
(3,812 Views)
Yeah, I guess that works but I was hoping for a more elegant soultion.
I am pulling the table contents from an Excel file and a couple of the headers have more than one space. So a simple find and replace space for new line does not work very well. That means I will have to set up special cases or somethign for some of them.
I know I could just hard code the headers but I am writing several programs for a department that uses simmilar but different input file formats for their tests and was hoping to only have to do this once. As much as I hate to I will probably just end up hardcoding it for now...
I am going to suggest word wraping for tables in the idea exchange.
(3,795 Views)
I'll vote for that.
(3,786 Views)
