Write 12-bit TIFF with LV
I am trying to help out one of my co-workers who needs to write a 12-TIFF file in LV.
He thinks he did 8-bit but the req. is for 12-bit.
So anyone that wants to straighten me out, please do so.
Thank you!
Ben
PS Tim (Mellowbuck) will reply with more details shortly.
Message Edited by Ben on 11-19-2009 03:02 PM
Message 1 of 17
(5,945 Views)
Thanks Ben!
My Main question is that I seem to be able to produce an image which consists of U16 grayscale, and then I use the IMAQ Write (shown below).
Upon re-opening the TIFF file (tim4.tif), each pixel intensity is truncated at 8-bit (255) at each pixel where it exceeded 255.
How do I keep greater than 8-bit resolution on this file? Or, am I missing something on opening the data?
Mello
Message Edited by Mellobuck on 11-19-2009 03:13 PM
Data Science Automation
CTA, CLA, CLED
SHAZAM!
Message 2 of 17
(5,934 Views)
If the image data is U16 and you format the image I16 that might be an issue.  I don't understand applying the color palet gray at the image write...could that be conflictign with the original image definition...
Hummer1
Message 3 of 17
(5,922 Views)
Caveat: I have never touched the IMAQ VIs.  That said, I am suspicious of the Cast Image VI, I would guess the default is a U8 Grayscale (I don't see anything to specify the type of Image you are casting to).
Message 4 of 17
(5,917 Views)
Accepted by topic author Ben
This seems to work...havn't checked the numbers, but they seem to come in and go out the same size.
Message 5 of 17
(5,898 Views)
Ben,
I started getting interacting in this forum for the exact same reason. I had a image processor chip that would give me a 12 bit image data and i wanted to map that into an image. I ended up converting it into a 16 bit value by manupulating the lsbs (adding 0000) and then mapping it.
Message 6 of 17
(5,883 Views)
Well first let me thank you all for the replies. I really appreciate it.
Tim has just arrived in the office and will check out your suggestions soon. I wll insist that you all get Kudos from him as well.
Ben
Message 7 of 17
(5,864 Views)
Thank you, Hummer! That was the correct solution. I removed the cast image and palette functions, and the numbers came in and out correctly. The image references had originally not connected without the cast image function, but I guess I got rid of the conflict somewhere along the line.
I'll let Ben know to mark this as a solution.
-Mello
CTA, CLA, CLED
SHAZAM!
Message 8 of 17
(5,862 Views)
You're welcome.
Darin.K's cast catch was important!
Hummer1
Message 9 of 17
(5,854 Views)
Hummer1 wrote:
You're welcome.
Hummer1
Should I mark his reply as the solution or should I just get him some more Kudoes?
Ben
Message 10 of 17
(5,850 Views)
