Write AVI file with XVID codec in Labview
Hello Vincent,
Does the Shipping Example mentioned the post above list the codec?
Can you share the VI you are using?
Can you share an NI MAX Report?
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Thanks for your cooperation!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 14
(1,506 Views)
Hello Thierry,
Sorry. I worked on others projects. Here's my MAX Report.
Kind Regards,
Vincent
Message 12 of 14
(1,477 Views)
Hello Vincent,
Can you also provide answers to the following two questions?
1) Does the Shipping Example mentioned the post above list the codec?
2) Can you share the VI you are using?
Kind Regards,
Message 13 of 14
(1,454 Views)
Hi, the reason is that you have a grayscale image and Xvid is for color images.
"IMAQ AVI2 Get Codec Names" will only show you compatible AVI compression codecs...
Use "RGB (U32)" in "IMAQ Create" and load with "IMAQ ReadFile 2" a color image. Now "IMAQ AVI2 Get Codec Names" will also show "Xvid MPEG-4 Codec".
You can store a grayscale image with Xvid MPEG-4 Codec, but I think LabVIEW will convert it to RGB first. This needs extra time. Consider a pipelined structure with "IMAQ Cast Image 2" vi.
Greetings
Andreas
Message 14 of 14
(1,011 Views)
