Write Data to Wonderware Historian from LabVIEW
I am looking to log data acquired using LabVIEW and CRIO to a Wonderware Historian.  If someone has experience in this area, would you mind sharing the way you accomplished it?  The cRIO unit will be connected to a TPC-2212 also.
Thanks in advance!
Bob C
(3,556 Views)
Hi BobbyCee,
I am not familiar with the Wonderware Historian since it is not an NI product, but it looks like it is a SQL server.  Where will you be hosting the SQL server?  How are you planning on communicating with it?
The Database Connectivity Toolkit is typically used for communicating with SQL servers.
https://www.ni.com/en/shop/labview/select-edition.html
You may want to contact Wonderwave to see if it is compatable.
Hope this helps!
Dayna P.
(3,531 Views)
