How to ramp voltage up, let it be steady for a while and ramp down and add sinusoidal on top of ramp
I am doing a project and I am asked to ramp voltage up, let it be steady for a while and ramp down add sinusoidal on top of ramp. I need some help since i m a beginner.
thanks,
Message 1 of 10
(7,184 Views)
First you need to make yourself clear about the requirement. Ask questions like
Ramp voltage up
  • At what rate it has to be ramped?
  • What is the starting and Endpoint?
How long it has to be kept steady?
Add sinusoidal on top of ramp
  • You just need the sine wave in the pattern of ramp or a ramp signal also has to be generated seperately?
  • what is the amplitude and the number of samples the sine wave has to have?
  • At what rate the ramp should be applied to the sine wave?
Since I haven't tried keeping sine wave on top of ramp I have made a quick example for your reference.
Good luck
Message 2 of 10
(7,167 Views)
Thanks for your  response P@Anand:
And ur right that i have to be more specific about my project.
What I am trying to do is make a ramp with starting at 0 and at 5 voltage. The ramp up period will be for 30 sec and steady state is about 5-6 minutes and then ramp down period will be 30 sec too.
The ramp signal will remain there but the sine wave will follow the ramp path. (sine wave will be on top of ramp.)
Sine wave will have variable  frequency and amplitude will be around 5 voltage.
The same rate at which ramp is  built can be used for the sine wave too.
This signal needs to be send to a analog stimulus isolator through BNC cable.
Please see the image below:
Thanks in advance
Message 3 of 10
(7,137 Views)
I used one example(that is attached below) but couldn't figureout a way to add sine wave on top of the ramp.
Any kind of help will be highly appreciated.
Thanks in advance
Message 4 of 10
(7,080 Views)
I made the sine wave ramp up but got stucked in holding it for 5-6 minutes and ramp it down again.
Please see the attached VI file made in LabVIEW and give me your valuable suggestion or help regarding this matter.
Message 5 of 10
(7,042 Views)
find attached a "Test-sweep"  ....
I have cutted  the original vi and put your formula inside....
It is for sure not ready to use - needs "some adjustment"; but should give you a playground  for improvement.
Sweep-Values are concatenated from three parts UP - HIGH - DOWN.   It gives the possibility to ramp-up and  -down with different values.  The resulting  "DC-values"  then get an Offset from your Formula.
Play first with different Sin_Amplitude  and use the  "single/append"- Button close to "STOP" in order to see, how it works.   I have stored on default Graph   three different Amplitudes ( 0,2V black ;  0,5V red ; 1V blue )
the vi is converted down to LV8.2  - hope all sub.vi's are  included ....   have fun
Begards
wha
Message 6 of 10
(7,020 Views)
Message 7 of 10
(6,998 Views)
Thanks Wha_x
Can I generate this signal from labview using DAQ card and BNC cable. If so can you tell me how? I need signal like this to be send through analog stimulus isolator.
Message 8 of 10
(6,937 Views)
Thanks, apok,
Which version are you using for this?
Message 9 of 10
(6,904 Views)
Hello friends,
I some how tried to ramp up a sine wave but I am struggling to hold it to be plateau( straight) for about 5-6 minutes and ramp it down. Please find my file below and help me!!
The ramp up time and ramp down should be 30 sec.
PLEASE HELP!
Message 10 of 10
(6,853 Views)
