Write Multiple Samples/Channels input dimension
When writing multiple samples/channels to a task using 1D array of waveforms, does the input have to match the number of physical lines in the port?
E.g. In my task I have defined virtual channels DO on line0 and line2 on a port containing 32 lines. Does my input have to contain 32 arrays or 2?
CLA
(1,378 Views)
Accepted by Quiztus2
Two lines are configured hence there are two channels in that task. The input should be a 1D array of waveform with 2 elements.
For DAQmx Write (VI) - Digital 1D Wfm NChan NSamp
data contains a 1D array of waveforms to write to the task. Each element in the array corresponds to a channel in the task.
(1,349 Views)
