Write PNG file failed when build exe, but run normally on the development platform
Thanks for Colin's solutions (http://www.colinzhang.net/2013/09/worklog-how-to-get-image-from-clipboard.html ). Perfectly solved the problem.
Can save clipboard picture as PNG format in executable file made by LV 2017.
Message 11 of 16
(1,029 Views)
Great to help you on this case.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
Message 12 of 16
(1,011 Views)
To Capture just the Active Window requires two keys to be pressed. ALT + PRINT SCREEN. The example mimics both keys being pressed but only releases the ALT key , leaving the PRINT SCREEN key pressed which then 'confuses' the .NET action (for me it also left most of the keyboard inactive).
SOLUTION: before releasing the ALT key insert another call to the kbd-event function to release the PRINT SCREEN key
arg1    (0x2A - PRINT SCREEN)
arg2    0
arg3    2    (Release Key)
arg4    0
Alt-PRINT SCREEN now works for me in both environments.
Message 13 of 16
(881 Views)
arg2    0
arg4    0
Message 14 of 16
(881 Views)
Hi All: I'm now using LabVIEW 2023 32-bit and it looks that the bug is still present.
I tried the solutions of this thread without any successs.
For others who have the similar problem (not able to read the ciipboard image when run as exe) I have a workaround.
Use this solution using a .net 8 dll that does the job.
I tested it with LV2023 and for me it works great, it only reads 24 bit images.
Message 15 of 16
(243 Views)
Or, alternatively, you can use IMAQ ClipboardToImage, but this function is only available if the Vision Development Toolkit is installed (by the way, the "opposite" IMAQ ImageToClipboard VI is also exist.)
Message 16 of 16
(233 Views)
