Write PNG file failed when build exe, but run normally on the development platform
refer to below picture, it is used to call WinAPI for screen shot, and then save to PNG file. This Vi run normally on the development flatform, but it is failed when build .exe application file. The error dialog pop-up "illegal path string, OS", but it is clear that the path is correct. Note: run the same PC with Win XP.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
Message 1 of 16
(7,514 Views)
Can you attach the screenshot of error dialog that pops up...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 16
(7,500 Views)
Thanks for your reply. Yes, but it is Chinese. I also put the dialog location here.
Colin Zhang
Message 3 of 16
(7,498 Views)
When i put the dialog before Write PNG File, no error output.
Colin Zhang
Message 4 of 16
(7,496 Views)
Accepted by topic author colinzhang
Update:
i have found the reason but no solution. In fact, the Clipboard.Get Image is not working when build exe application. But this is the private Invoke Node, can't get any support from NI.
It seems to become to the public Invoke Node on LabVIEW 2012 version, who can help to verify it on LV2012 version? Thanks very much.
Colin Zhang
Message 5 of 16
(7,457 Views)
I have lv2012 and it does not work here either.
Has anyone found a solution?
Message 6 of 16
(7,343 Views)
No, it seems a bug that has reported to NI R&D.
Colin Zhang
Message 7 of 16
(7,336 Views)
oooh, Yes, I change to use .Net reference to copy the screenshot. Please visit my blog site for solution.
Colin Zhang
Message 8 of 16
(7,334 Views)
Thx man 😃
Message 9 of 16
(7,331 Views)
I find another solution that get the clipboard image. Hope it is helpful for next follower.
Use the IMAQ ClipboardToImage.vi under vision module, it can get the image successfully, but not verify it after build executable file.
Refer to below code,
Colin Zhang
Message 10 of 16
(7,241 Views)
