Write Spreadsheet String
If I wanted to be able to offset each group of data seperately (using four seperate "Tare" booleans) could I use the same idea "P Anand" illustrated in the consumer loop?
Message 21 of 22
(750 Views)
An index array seperates out each waveform. I wanted 4 arrays of 6 waveforms. What is the best way to split the initial 1d array of 24 waveforms?
Message 22 of 22
(748 Views)
