Write Spreadsheet To File even if path doesn't exist (yet)
I am interested in using Write Spreadsheet To File to log some data to my disk.  What is the easiest way to include this VI and tell it to create the folders if they don't already exist.
For example:
Using that example, if no "Data" folder can be found on my Desktop, how can I have LabVIEW create the "Data" and "Test1" folders necessary to create Test1.csv in the specified location?
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 1 of 8
(5,729 Views)
Accepted by topic author MrHappyAsthma
I ended up making a VI out of this community example https://forums.ni.com/t5/Example-Code/Creating-and-Opening-a-File-from-a-Non-existent-File-Path-usin...
Message 2 of 8
(5,700 Views)
Is it possible to share your VI as I am unable to reach the link.Thanks
KInd regards,
Waleed El-Badry, MSc., CLAD MCPD
Message 3 of 8
(4,576 Views)
Just use the Create Folder Function instead.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(4,570 Views)
Examples got moved around fairly recently.  So I'm not surprised if the link doesn't work.  See if this fixes your issue.
Message 5 of 8
(4,567 Views)
Or use \vi.lib\Utility\libraryn.llb\Create Directory Recursive.vi
Message 6 of 8
(4,565 Views)
Which can now (at least as of 2019) be found in the File I/O->Advanced File Functions palette.
Message 7 of 8
(4,562 Views)
So what's the difference between the Create Directory Recursive function and the Create Folder function?  They both seem to create the intermediate folders on the way to creating the target folder.  Curious as to why they both exist...
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(4,541 Views)
