labview2018 DAQmx library
Hello everyone,
I recently installed labview2018 on my new system, but somehow I realize that it doesn't contain libraries such as IMAQ and DAQmx, therefore, the VI used to run on my old system (labview2014) can't run on the new system. Do labview 2018 provide VI libs for these or I need to manually copy paste from the old system?
Thanks.
Message 1 of 20
(5,761 Views)
Hi utoct,
did you install those device drivers after you installed LabVIEW?
Message 2 of 20
(5,728 Views)
Yes. But it seems like NI doesn't have DAQmx application development support for labview2018.
Message 3 of 20
(5,725 Views)
Sure it does!  It's part of the Driver set.  It installed on my PC ...
Bob Schor
Message 4 of 20
(5,710 Views)
Does it show up in labview functions?
Message 5 of 20
(5,705 Views)
Yes.  It shows up under Measurement I/O >> DAQmx just like it did in earlier versions of LabVIEW.
Message 6 of 20
(5,702 Views)
Which version of labview and NImax did you install? I installed NI MAX 18.0.1, it doesn't have labview support, but I found that in NI Max 17.6.
Message 7 of 20
(5,695 Views)
You don't install NI-MAX, you install NI-DAQmx which will install MAX with it.  It is version 18.0  or higher
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Message 8 of 20
(5,692 Views)
I installed NI-DAQmx 18.1 after I installed labview2018. But I still don't have DAQ functions in labview.
Message 9 of 20
(5,689 Views)
Check to make sure support for LabVIEW 18 is checked when you install the device drivers.  It should be on by default, but perhaps for some reason it was unchecked.
Message 10 of 20
(5,685 Views)
