02-08-2013 03:30 PM
Hi:
I need to write a program in LabView that is capable of testing two parts at the same time.
Explanation:
I star the test on a unit, once all the electrical test is done move that unit to the pressure test without loosing the current test information and continue the test of the unit thewn generate a serial number only if it passes all the test. Then while the previous unit is going thru the pressure test star testing another unit for the elecrical test and so on.
I am using LabView 2012
02-08-2013 03:40 PM
What is your question? You can use test stand to do all of that.
02-08-2013 03:44 PM
And your question is ?
Try to look at NI TestStand, it is a product for this kind for test stations.
02-09-2013 05:46 AM
@Toro wrote:
[...] generate a serial number only if it passes all the test. [...]
Grrr. ![]()
02-11-2013 01:02 PM - edited 02-11-2013 01:04 PM
From what you have described, I agree with what has been answered above. TestStand is specifically designed for. If you would like to provide more information about your application we could give you a more detailed response. For more information about TestStand follow this link
Ryan
