Write a spreadsheet from an array of string
Because I have 8760 results and excel supports only 256 values in 1 line.
Message 11 of 19
(1,997 Views)
Hi ,
you can use write to spreadsheet file function and make transpose = true.
Message 12 of 19
(1,992 Views)
Refer the following attachment...
Message 13 of 19
(1,991 Views)
I tried your solution, but somehow my connection is not right.
Take a look on the attached file.
Thanks in advance.
Message 14 of 19
(1,984 Views)
Cot,
write to spread sheet doesn't support the sring input in previous version i.e u cannot wire the sring array to this function for the versions below 8.6...
what u can try is if the data wat u r simulating does not contain any of the string/characters, then try to convert the string value to numeric and u can wire it to the write to spread sheet file function....
check this...
LV 8.0, 8.6, 2011,2012,2013 WinXP
Message 15 of 19
(1,955 Views)
Hi Cot,
Is there a special reason for converting your numeric data to string format?
I think 9000 values shouldn't be a problem for excel.
(http://office.microsoft.com/de-de/excel-help/spezifikationen-und-beschrankungen-in-excel-HP010073849...
Maybe you can try some examples of your LV example library.
I tried different possibilities to save data. It's not programmed very nicely, but maybe it helps you.
Message 16 of 19
(1,926 Views)
Accepted by Cottbus
Hi there,
Thanks everyone for the help.
I tried different solutions and in the end I did in a different way using numbers instead of words.
Message 17 of 19
(1,904 Views)
@subbzz wrote:
Cot,
check this...
I hope we're not going to start polluting the forums with this 'textese'.
Message 18 of 19
(1,891 Views)
Hi there,
That's more or less what I did. Instead of having a tex message, I used different sequencies of numbers, then exported to excel and there I converted the numbers to text again.
Thanks once more for all the suggestions. I appreciate a lot.
Message 19 of 19
(1,876 Views)
