Write an Array of Clusters to Text file ( Excel or Txt)
Dear Members,
Im developing a vi as a control panel to manage some other vi's that are remotely controlled. I'm using a property node to retrieve the information that i need to show in the control panel that I'm building, but i need to save this information into some kind of text file(excel, .txt).
I have attached a file to show the type of variable that I'm dealing with.
(5,405 Views)
A text file would likely be your best best.  You can easily unbundle the cluster and format the individual elements into a string and write to a text file.
(5,397 Views)
Unbundle means separate each array of the cluster? How do I do it?
(5,395 Views)
Unbundle by Name
(5,387 Views)
This example might be a little more help to you.  I left the formating of the data up to you.
(5,382 Views)
Thank you!
One more thing. There is a way that i write all this output data all thogheter in a single text file?
(5,375 Views)
