Write data from 12 element cluster to excel
Hi XebeXUC,
Am I even near the solution?
Well, you get nearer 😄
What about using a case structure?
IF remainder == 0 THEN
   save data to file
ELSE
   do nothing
ENDIF
Message 11 of 25
(1,363 Views)
What would I fill in the false case then? I can't have nothing in there
Edit:
Got it! I  don't have to go through the case 😄
Thanks for your help and patience 😄
Message 12 of 25
(1,361 Views)
Hi XebeXUC,
do you really have big problems to implement a case structure to save data only when needed?
Message 13 of 25
(1,358 Views)
It's monday for everyone :s
I just come back here too fast instead of thinking twice (or three times).
However I still failed with my time stamp, the string doesn't work with the array. And converting it to double like the rest of the data gives again a big number.
But that's not a big issue, I don't think it really needs a time stamp.
Message 14 of 25
(1,354 Views)
Hi XebeXUC,
Hint: when converting the timestamp to a DBL number fails you  might convert your measurement values to strings and use an array of strings…
Message 15 of 25
(1,351 Views)
Oh yeah, that worked great, only negative side is that I seem to be losing digits, but the sensors are probably not even that sensitive so rough numbers should be good enough.
Message 16 of 25
(1,355 Views)
Hi Xebe,
why do you lose digits? Use a better format string!
Message 17 of 25
(1,348 Views)
try Time to XL.vi
Excel an LabVIEW use different "Epochs"
WARNING Time constants do not travel well adjust that constant for your timezone
Message 18 of 25
(1,346 Views)
Basically digits after the comma/point.
So 1,9 becomes 2...
But thanks for the tip, I found a better one indeed.
Edit: apperently it isn't that much better :S
Message 19 of 25
(1,334 Views)
Hi Xebe,
Basically digits after the comma/point. So 1,9 becomes 2...
Using FormatIntoString with a format of %f will give you "1.9"…
Which one?
Well, which one isn't better?
Message 20 of 25
(1,328 Views)
