Write data to array of strings in cluster by reference
Im sorry but i cant follow you....
As i said i need to put in values in my array of stings at different places, for example index 2 and number 50.
I think i need a concrete example to understand.
Message 11 of 20
(394 Views)
I see now that i have to populate each index in numeric order to fill my array.
For example if i want to write 50 at index 2 i need first to write zero at index 0 and 1.
Is there a way to write 50 at index 2 without populate index 0 and 1 first?
Message 12 of 20
(393 Views)
Hi tokar,
No.
In LabVIEW you cannot have an array that only has an element at index 2, but not for index 0 & 1…
(In string arrays you can write empty strings at index 0 and 1 before appending "50" at index 2. Is this the only reason to hold numeric values in a string array?)
Message 13 of 20
(388 Views)
Answer: Ah ok
Answer: Perhaps it should be better to use an array of numeric values?
Message 14 of 20
(385 Views)
Hi tokar,
This depends on your requirements!
You didn't list all of them yet…
(Until now you just wrote about "how do I solve my problem?", but not about "what exactly is my problem?"…)
Message 15 of 20
(380 Views)
Kind of, reshape the array before. You will get default elements for new array elements. There is a node called reshape array that will grow or shrink an array.
place element at index while growing array if necessaryplace element at index while growing array if necessary
As Gerd said, arrays are always contiguous. There are no holes.
In other languages, you get a segmentation fault or a compiler error when writing to an array location that does not exist. (Or you modify the program in even more undesirable ways).
LabVIEW checks for out-of-bounds access and silently ignores the write. If you read from an out-of-bounds location, you get back the default value, which for numerics is zero, for strings an empty string.
Message 16 of 20
(361 Views)
People are helping you with your problem as requested, but in general you shouldn't use Front panel objects as data containers so the whole "reference front panel objects" is unnecessary/unwanted.
Indicators are just that, indicators. Keep the data in a cluster in a shift register.
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 20
(352 Views)
Hi tokar
First you need to initialise the array using any empty string and choose a size appropriate for the number of entries expected. Then you can use replace subset to change the contents of any index. all unchanged entries will be blank and not 0 (zero). If you want zeros initialise the array with a string entry "0".
I can't provide a snippet or image, no LabVIEW where I am.
Message 19 of 20
(294 Views)
Thank you all for all good information.
I solved my problem and got a better understanding of arrays now.
Cheers to all!
Message 20 of 20
(286 Views)
