Write multiple waveforms in TDMS
Hi everyone,Smiley Happy
Here is my problem, I have 5 waveforms with 3 y values each and I would like to write these 5 waveforms in a TDMS file.
But when I connect a simple waveform to the "TDMS write" function it's work, but when I connect mulitple waveforms, the wire is broken:"Polymorphic terminal cannot accept this data type".
Thank you for your help!
(3,021 Views)
Can you post some code?  When I try to wire an array of waveforms, the TDMS Write takes it just fine.
(3,015 Views)
Hi Crossrulz Smiley Happy
I found the solution by myself!
Thank you for your reply anyway!
(2,983 Views)
