Using nidll.tlc: could not find *.obj
I am using the NI SIT, and with it comes a nidll.tlc which I can use to build Matlab models into .dll files. When I build, Matlab would say that the build was successful, but not .dll can be found anywhere. In the Matlab screen, the only thing that indicates something went wrong is: Could Not Find C:\Program Files\National Instruments\LabVIEW 2010\examples\Simulation Interface\Sine Wave\sinewave_nidll_rtw\*.obj
Can someone help with a) figuring out why no .dll file was generated, or b) why this *obj file could not be found? Thanks.
>> mex -setup
Please choose your compiler for building external interface (MEX) files:
Would you like mex to locate installed compilers [y]/n? y
Select a compiler:
[1] Lcc-win32 C 2.4.1 in C:\PROGRA~1\MATLAB\R2008a\sys\lcc\bin
[2] Microsoft Visual C++ 2008 in C:\Program Files\Microsoft Visual Studio 9.0
[3] Microsoft Visual C++ .NET 2003 in C:\Program Files\Microsoft Visual Studio .NET 2003
[0] None
Compiler: 3
Please verify your choices:
Compiler: Microsoft Visual C++ .NET 2003
Location: C:\Program Files\Microsoft Visual Studio .NET 2003
Are these correct [y]/n? y
Warning: MEX requires that the Microsoft Visual C++ 7.1
directories "Vc7" and "Common7" be located within the same parent directory.
(Expected to find these directories in 'C:\Program Files\Microsoft Visual Studio .NET 2003'.)
Trying to update options file: C:\Documents and Settings\HILContUser\Application Data\MathWorks\MATLAB\R2008a\mexopts.bat
From template:              C:\PROGRA~1\MATLAB\R2008a\bin\win32\mexopts\msvc71opts.bat
Done . . .
  Warning: The MATLAB C and Fortran API has changed to support MATLAB
           variables with more than 2^32-1 elements.  In the near future
           you will be required to update your code to utilize the new
           API. You can find more information about this at:
           Building with the -largeArrayDims option enables the new API.
### Starting Real-Time Workshop build procedure for model: sinewave
### Generating code into build directory: C:\Program Files\National Instruments\LabVIEW 2010\examples\Simulation Interface\Sine Wave\sinewave_nidll_rtw
### Invoking Target Language Compiler on sinewave.rtw
tlc
-r
C:\Program Files\National Instruments\LabVIEW 2010\examples\Simulation Interface\Sine Wave\sinewave_nidll_rtw\sinewave.rtw
C:\SimulationInterfaceToolkit\2010\ModelInterface\tmw\R2007b\nidll.tlc
-OC:\Program Files\National Instruments\LabVIEW 2010\examples\Simulation Interface\Sine Wave\sinewave_nidll_rtw
-IC:\SimulationInterfaceToolkit\2010\ModelInterface\tmw\R2007b
-IC:\SimulationInterfaceToolkit\2010\UserInterface\R2007b\tlc_c
-IC:\Program Files\National Instruments\LabVIEW 2010\examples\Simulation Interface\Sine Wave\sinewave_nidll_rtw\tlc
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\mw
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\lib
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\blocks
-IC:\Program Files\MATLAB\R2008a\rtw\c\tlc\fixpt
-IC:\Program Files\MATLAB\R2008a\stateflow\c\tlc
-aEnforceIntegerDowncast=0
-aFoldNonRolledExpr=0
-aInlineInvariantSignals=0
-aInlineParameters=0
-aLocalBlockOutputs=0
-aRollThreshold=5
-aZeroInternalMemoryAtStartup=1
-aZeroExternalMemoryAtStartup=1
-aInitFltsAndDblsToZero=1
-aGenerateReport=0
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=0
-aLaunchReport=0
-aGenerateTraceInfo=0
-aForceParamTrailComments=0
-aGenerateComments=1
-aIgnoreCustomStorageClasses=1
-aIncHierarchyInIds=0
-aMaxRTWIdLen=31
-aShowEliminatedStatements=1
-aIncDataTypeInIds=0
-aInsertBlockDesc=0
-aSimulinkBlockComments=1
-aInlinedPrmAccess="Literals"
-aTargetFcnLib="ansi_tfl_tmw.mat"
-aIsPILTarget=0
-aLogVarNameModifier="rt_"
-aGenerateFullHeader=1
-p10000
### Loading TLC function libraries
### Initial pass through model to cache user defined code
### Caching model source code
### Writing header file sinewave_types.h
### Writing header file sinewave.h
### Writing source file sinewave.c
### Writing header file sinewave_private.h
### Writing header file rtmodel.h
### Writing source file sinewave_data.c
### Writing header file rt_nonfinite.h
### Writing source file rt_nonfinite.c
### TLC code generation complete.
### Generating TLC interface API.
## SIT 2010 Modifying sinewave.c file
## SIT 2010 Modifying sinewave.h file
## SIT 2010 Generating Ports Readme file
### Successful completion of Real-Time Workshop build procedure for model: sinewave
(4,485 Views)
This appears to be a pretty complex issue.  I'm not sure why no .dll file was generated off the top of my head, but I'll continue to work on this and try to figure out why it's not.
Austin S.
Academic Field Engineer
(4,466 Views)
Hi Guys,
        I am also having the same problem. Did anyone solve this issue.
Kumar
(4,240 Views)
Hi Kumar,
Are you using a supported compiler?  If you are using Visual Studio Express, there are a few more steps you need to follow to set everything up correctly, which you can find here:
Can I Use a Free Compiler with SIT?
Jayme W.
(4,224 Views)
  Thank you for your comment. I am using Visual studion 2008.
I want to indicate something here. Eventhough, I get the same error, I am able to generate the .dll file and the .dll file works very well. I wanted to make sure that this error does not create any further error when using the .dll file.
Kumar
(4,209 Views)
