Replace series of 0s with one 0
Hi. I have big chunk of 1 and 0 . I would like to replace a 0 for every greater than 5 number 0s , the same for 1s
like this.
if this is my input data:  000000111111110000001111111000   I would like to change it to 0101000
Could you please help me on this one and show me with a sample code How I can do it in LabVIEW. Many thanks
Message 1 of 25
(3,732 Views)
Message 2 of 25
(3,723 Views)
could you please attach the vi, also is ther any way to delete the 0s in the end ( because number of 0s is less than 5 )
so 11111100000111111000 should be changed to 101
Many thanks
Message 3 of 25
(3,719 Views)
Here's a non-regex solution. 😄
Not fully tested. Please verify correct operation.
Message 4 of 25
(3,707 Views)
Any advantages over the regex from Darin? Is it something to do with memory/speed/performance?  Just curious.
Message 5 of 25
(3,697 Views)
You should benchmark it. Are the strings big enough that it actually matters?
Message 6 of 25
(3,693 Views)
Actually I wouldn't know. This is something only "tintin_99" would know. But I just saw Darin's example and looks simpler (code wise) than yours. So I'm thinking if regex has any shortfalls (in this case) compared with non-regex version.
Kas
Message 7 of 25
(3,687 Views)
This is in direct contradiction of your first message, where the trailing tail was retained.
If you want this functionality, you can modify my last case structure on the right and delete the "initialize array" and make the output tunnel to "use default if unwired".
Message 8 of 25
(3,682 Views)
Many thanks
Message 9 of 25
(3,679 Views)
@tintin_99 wrote:
Many thanks
Yes, just modify the innermost case structure. for example you could make folliwng cases:
  • [4..] Same as current case
  • [default] output empty array.
etc...
Message 10 of 25
(3,674 Views)
