Write only specified range of data from 2D array to spreadsheet string?
Hello all,
My issue today is a simple one, but I can't for the life of me find an answer using search. I have a 2D array of data points (Y values) with their corresponding index numbers. When I run my VI, I get back an array of 10's of thousands of values, but I want to be able to extract only a few hundred values (specifically, one or two periods of a periodic sound wave) at very most to display in a spreadsheet string for later calculations in Excel.
I have managed to get the data written to the spreadsheet string easily, but I am stumped as to how to specify the range (using the index values) to allow to be written to the spreadsheet string. I have tried "Delete From Array" but I must be missing some funcionality, because I can't seem to delete all values both above a max index and below the min index specified (in order to just get the values between max and min).
Help a newbie out?
Appreciated.
(2,863 Views)
Accepted by topic author Zed8
(2,859 Views)
... Doy.
Thank you. I feel dumb now.
(2,852 Views)
