keeping track of array memory usage
Hello everyone,
I am a mech engineer who has programmed casually over the years and has recently been assigned the task of creating an HMI for a compressed air system using Labview 2010.
Two tasks I need to complete involve logging alarm history and displaying a data trend.
My question is this -
I would like to hold the alarms (an array of clusters containing a timestamp and the alarm description) and data (timestamp and respective data values) each in a holding array until they get to a certain size, and then dump them into a csv file. How can I monitor the memory being used for each array so that I know when to dump it?
Also, datalogging is not something I have any experience in. Does anyone know anyone know where I can find any references online that go over good datalogging practices? I was looking for some that are specific to Labview but didn't have much luck.
Thanks everyone in advance!
(2,672 Views)
Unless the description strings vary wildly in size, start with "array size" 😄
(2,664 Views)
If you are just getting started on this project you might want to take a pause and check out TDMS (Technical Data Managment System)
LabVIEW 2012
(2,659 Views)
