Write to Spreadsheet .vi append file
hi,
I have a "write to spreadsheet.vi" inside a time loop. I have an array that is updated every second and i save it to a file using the write to spreadsheet.vi. I do not want to append the file but since its a short time loop, labview always gives me a prompt to let me confirm the replacing of the file.
Is there any way to stop the prompt and just let me replace the file?
Thanks a lot,
Tai
(3,019 Views)
Hi BestPker,
If you open the "writetospreadsheet.vi" you will see the "Open,Create and Replace File.vi" one of this vi's inputs is a Boolean labeled "Advisory Dialog". You could wire a constant "False" into that input if you don't want see the advisory dialog you are seeing. You might consider wiring a control into the  input and adding that control to your connector pane for future use. In either case I would recommend renaming this vi to something else like "mywritetosreadsheetfile.vi". Hope this helps.
Cheers,
--Russ
(3,015 Views)
Thanks Russ, this is what i was looking for.
Tai
(3,011 Views)
