disable context help
I have written a stand alone application, and during testing, I found that Ctrl+h brings up the context help window.  I don't want this to occur.  Is there any easy way to remove this operation?  I have been using an event structure with the "Menu Selection? (App)" event and discarding it if the tag was "APP_SHOW_HELP", but I was just wondering if there was a better way.  Oh, I'm using LV 7.1 if it makes a difference.
Thanks for your help,
Jon
(4,187 Views)
Hi Jon,
I think discarding the menu event is the only way to do it.  If you want to disable the Ctrl-H key combination, just add an event for that, too.  Here's what I came up with:
-D
Message Edited by Darren on 06-15-2006 03:57 PM
(4,185 Views)
Thanks for the quick and thorough answer Darren,
I didn't see anything in the menus/vi properties about disabling the help window, so I wanted to make sure I wasn't missing something obvious.  After changing and rebuilding, it works as I had hoped.
Thanks again,
Jon
(4,177 Views)
Don't forget that you have to account for the capital H as well.
___________________
Try to take over the world!
(4,175 Views)
Good call...capital H is ASCII character 72...a perfectly valid character to check if the user has Caps Lock on.  Note that Ctrl-Shift-H does not launch the Help window, so you don't have to worry about that corner case.
-D
(4,168 Views)
