Write to measurement file with dynamic file name
Is it possible to dynamically change the name of the output files created by the "Write to Measurement File" express vi?  E.g. adding the frequency that the measurement was made at to the output name?
Matt
(3,047 Views)
There's Filename input on this express VI. You can manipulate file name inside block diagram and input to it.
(3,044 Views)
...and the only away to modify the block diagram of an express VI is to convert it to a normal VI by right clicking on it and saying to open its front panel. Remember that this conversion only goes one way. You can't turn it back into an express VI.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,037 Views)
Mike...
Mike, I think you misunderstood the previous post.  The express VI itself has a file input.  You can create the file name to be whatever you want and wire it into that input.
GCentral
(3,033 Views)
