Write to measurement file (.xlsx)- Append new data but in new sheet/table
Hi all,
I searched in all the related forums for "Write to Measurement File" and also went through the help provided with the Express VI but could not find any lead to this.
Details:
  • I want to write to measurement file (here .xlsx) two times.
  • I am writing 'Target Positions' (column 1) Vs 'Chirp Amplitudes' (columns 2-8)
  • I am using two different step sizes for Target Positions- StepSize (resolution)=5, StepSize=1
  • Currently, I am recording StepSize=5 data in xxx_StepSize_5.xlsx and that from StepSize=1 in xxx_StepSize_1.xlsx
  • Now, I want to get rid of the second file xxx_StepSize_1.xlsx and write/append the data in the same file for StepSize=5 (xxx_StepSize_5.xlsx)
  • This data should be written in a new sheet/table next to StepSize=5 data sheet/table
Questions:
  • Is it possible with the currently used "Write to Measurement File" Express VI?
  • How do I configure this Express VI to achieve this?
  • If not possible, any other alternative?
Rahul
(2,669 Views)
Accepted by Raul22
Hi Raul,
No.
No way.
Use functions from RGT (Report Generation Toolkit). You need MS Office installed on the computer you want to generate the report on…
(2,666 Views)
