Write to measurement file
Hi guys,
i'm saving analogue data to write to measurement file in LVM format. When i open the file with word pad or with note, there is a gap in the beginning of every raw and then follows the number.
Is there a way to delete this gap?
Thank you in advanace for your time
BR,
Elias
(2,249 Views)
Did you specify a width for the data?  If you did, there will be spaces to make the number string be have the width number of characters.
GCentral
(2,199 Views)
