how to mass down convert 2010 to 8.6 (question not a request)
I have near 700 vis and 75 ctls mixed between LV2010 8.6. Is there any easy way for me to mass down covert them all to 8.6? I own LV 8.6 and LV2010. On 2010 I found a mass compile function but I cant pick which version to compile to.
Message 1 of 9
(3,430 Views)
I think you should be able to do it with some scripting help.
Basically a VI that will open a list of VI's (array of file paths), then does the Save for Previous method to save to the earlier version.  Just doing all of that in a For Loop.
There is probably a VI somewhere in the forums someone has posted that does that.  Do a search.  If I can find it, I'll post the link here.
Message 2 of 9
(3,418 Views)
Accepted by topic author schddc
Masscompiling is to convert to the the current version.
What is the relation between all the VIs? Are they all subVIs of a few toplevel VIs? Are they all part of a LabVIEW project? Are they all in a few folders?
  • If there are only a few toplevel VIs, just open these and convert them down using "save for previous", they will drag all depedencies (subVIs, controls, etc.) down with them to the new output location.
  • If they are all in a LAbVIEW project, downconvert the project using "save for previous".
  • If they are not part of a project, create a new project and all all relevant forlders as snapshot folders. Now donwconvert the newly created project.
In all cases, you will get a new set of all VIs in a new location. You cannot donwconvert overwriting the existing VIs.
Message 3 of 9
(3,417 Views)
Here is a VI I created based on what I was thinking.  (I couldn't find what I was looking for when I searched.)
Warning.  I haven't fully tested this.  And after reading Altenbach's message about the dependencies, I'm not sure how this would work.
What I have is you give it a path to a folder where all of your VI's are saved.  You give a path to where you want the VI's saved to.  It will gather a list of all the filenames in that folder, open then individually, then save for previous.
I haven't done any special error handling (like if you had a non-LabVIEW file in the folder.  I haven't handled subdirectories.  (OpenG does have some useful VI's such as a recursive file list.)  And as I said, I don't know how it would handle having a dependency in the same folder.
So use this cautiously as a basis to programmatically cycle through VI's to convert.  I'd recommend working on a few at a time, then a bit more complicated things, before turning this loose all at once on a full directory of 700 VI's.  Make a safe backup of that before going on, also.
(It turns out that the methods used weren't scripting functions after all.)
Message 4 of 9
(3,407 Views)
they are mostly subVIs but not all of them are used. None of them are projects. I have 3 folders containing a folder structure that looks like this.
├───Base Level <-VIs linking to dll functions
│   ├───Group A
│   ├───Group B
│   ├───Group C
│   ├───Group D
│   ├───Group E
│   ├───Group F
│   ├───Group G
│   └───Group H
├───Top Level Tests <- VIs using the base level subVIs
└───tools <- Helper VIs and ctls
I do have something I call a "diagram VI" which is a VI I have containing all my Base Level and Top Level VIs in the block diagram organized in their groups as a quick reference. However im not positive all my VIs are listed in it and I know it doesnt contain any vis in the tools but some of the Top level VIs use the tool VIs.
Thanks for the VI, ill do some experiementing
Message 5 of 9
(3,378 Views)
Do something like this.
Message 6 of 9
(3,354 Views)
The heart of your VI is the same thing as I posted several messages ago.  You just created a different user interface around.
Also, please don't post VI's to the forums that are set to run automatically when called.
Message 7 of 9
(3,351 Views)
Create a new VI where you dump all vi's.
Use Save as previous version. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(3,342 Views)
If was just a few VIs, I would tell you to put them all into a project and do the Save for Previous on the project.  But with that many, I would highly recommend the scripting method that Ravens Fan gave you.
GCentral
Message 9 of 9
(3,322 Views)
