Write to text file - question
How can I add on top of .txt file "caption", for example I want in my example add "date" and "time".
date                  time
12.3.2012    12:46:44
_________________________
Rookie; LV 2011 on WIN 7
(2,587 Views)
Accepted by hlod
All you had to do is put in the header before the loop. Here it is, but it's in LabView 2009. If it doesn't work on yours tell me.
David.
(2,574 Views)
Here's the same with a little bit less code. 😉
(2,555 Views)
