Write waveform timestamps with data in TDMS file
I am attempting to write data from an array of waveform data derived from a multi sample DAQmx acquisition, but I have found where I have used the get date / time function within my while loop passed to a TDMS Write in series with another being passed the waveform data, that I have many more data points than timestamps, as I am getting a timestamp then the list of sampled points.
I am looking at using the timestamp data from the waveform, but I'm not sure how to make this work.  Attached is an example where I have attempted this, but just managed to obtain mismatched data types.
Could anyone please offer some advice on how to get the following structure in my file:
timestamp of sample | channel 1 sample | channel 2 sample | .... | channel N sample
Dave
(4,688 Views)
Accepted by topic author djroseman
I'm not quite clear about your use case in the attached VI. However, you should give input of channel names to the 2 "TDMS Write" nodes since they have different type of raw data.
(4,667 Views)
That was the thing I was missing - adding that built my file as expected.
Thanks for your assistance
Dave
(4,646 Views)
