Write waveform to file issues
It looks like I've figured it out for the most part. I found out I was using the wrong command anyway, I should have been using "export waveform to spreadsheet file" so that the information was actually legible. The only problem I am still facing is that the program is not creating the file name based on run date and is rather asking for user input once the first iteration of the loop is completed. I removed all of the colons and dashes from the time stamp so the file names should only be numbers but it still doesn't automatically generate the names.
Message 11 of 13
(826 Views)
I may have a clue: Does every directory in the path exist? Open File or the equivalent inside Write (or Export) to File does not create folders or directories. If any folder or directory in the path does not exist an error will occur.
Lynn
Message 12 of 13
(824 Views)
Remove the "\" from the cancatinate string.  The Build Path will take care of that for you.  But that extra \ is the reason for your <Not a Path>, which then causes your dialog.
Message 13 of 13
(808 Views)
