Writing characters to text file to convert the data into image
Hi Hasan,
is the data from your post before the entire image? Is it all you have? Can you upload a vi with your data in a string constant? What is the expected image format? Looks like jpg for me.
Mike
Message 11 of 31
(2,172 Views)
While we are at this. Kudo this idea.....
Message 12 of 31
(2,170 Views)
I need to write all the data into text file. The value 0x00 is interpreted as 0x20 in labview. how can I handle this?
Message 13 of 31
(2,165 Views)
Hi Hasan,
as already mentioned, write your file as binary file.
Can you upload such an example?
Mike
Message 14 of 31
(2,161 Views)
The problem i think is that .... while writing data to the file, labview converts 0x00 to 0x20 ...... how can i handle this?
Message 15 of 31
(2,160 Views)
hi mike... this is not the whole data, its only the frst package. I have 12 packets similar like this.
am attaching the file that i need to write them in text file as characters and then convert the extension of that txt file into jpg. so that i can read the image.
i have attached the whole file. I need to display this file as jpeg image. the image should look like the attached image (image.jpg)
Message 16 of 31
(2,151 Views)
Mike
the source code is very cumbersome to obtain all the data one by one following the protocols.
 can you please tell me how to convert the file (example values.txt) into jpeg image  using labview?... the image should look like the second attachment (image.jpg) in the previous post
Message 17 of 31
(2,148 Views)
Hi Hasan,
if i write it like this, then i get the result you show in your post.
Mike
Message Edited by MikeS81 on 04-13-2010 09:52 AM
Message 18 of 31
(2,147 Views)
Mike
How are you converting/writing this hex file into jpeg image? can you please post your code?
what i am getting the image is attached here (Distorted image.jpg)
only first row is visible but the rest of the image is distorted. Please tell me how can I obtain the actual image?
Message 19 of 31
(2,142 Views)
Hi Hasan,
if you have the image data as text, as you have posted before, then the attached code works to generate the jpg file.
Mike
Message Edited by MikeS81 on 04-13-2010 10:08 AM
Message 20 of 31
(2,132 Views)
