Writing elasped times into a spreadsheet
I have three gates which I am timing to see how long they are switched on for. I am trying to write the elasped time data into a spreadsheet, however every time a new elasped time is created it asks me which file to save the data to! I have put a TRUE on append to new file, which I thought would solve the problem. How can I stop this happening so that all elasped times are transferred to the file without the user being prompted and the subsquent reading being overwritten?
Please see my file attached,
(2,677 Views)
I forgot to say a thanks!
THANKS!
(2,676 Views)
As the help for the function explains, if the file path input is empty, you get prompted for the file name. Use a front panel control or at least a shift register so that after the first prompt, you pass it back the next time.
Using a timed loop with an event structure inside does not make any sense to me. You could also eliminate most of those local variables.
(2,674 Views)
